Lestdog
Jan 30, 2023Aspirant
Login Page for CM1000v2 just refreshes when I try to login
When I go to http://192.168.100.1. and try and login, nothing happens but a page refresh. I did a factory rest and tried "admin" & "password" and again. The page just resets the login form. Any ...
- Feb 07, 2023
Definitely check to see if you can get it RMAd. Ya seems like something is borked on the web page service side.
Good Luck.
Lestdog
Feb 07, 2023Aspirant
Thanks, yeah still the same deal. I just have to think the page server is corrupted. I don't what this means as far as security but the modem is working. So I'm not sure if I should just live with it or RMA it. In the meantime I can just live with it.
Thanks again.
Feb 07, 2023Guru - Experienced User
Good Luck.
