Zalophus
Sep 16, 2024Aspirant
Loging in to CM1100 Modem
modem http://192.168.100.1. login doesn't work. "Times out", using FF, Chrome, and MS Edge. Is there another log-in I can use?
- Sep 17, 2024
No suggestion is only to test to make sure a PC can get to the Modems web page. If so, then you'll need to contact the Mfr of your wifi router system for there help and support to see what can be done as that router maybe the cause of the issue.
Zalophus
Sep 17, 2024Aspirant
I understand the point of your suggestion, but I don't have a long enough cable to reach my PC from the modem, so assuming your process allows me to connect with the modem, and since I need my router for all my other devices, is there a work around to bypass the router, even when it's on? Otherwise, the work around you propose is not a permanent solution.
Sep 17, 2024Guru - Experienced User
