buckduck12
Mar 17, 2023Tutor
Looking for Netgear CAX80 Beta Firmware 2.1.3.1
Looking for beta firmware version 2.1.3.1 for my netgear CAX80. I read through the forums and found that the only way to fix the WiFi calling issue with this device (ipsec alg) is to install firmware...
buckduck12
Mar 22, 2023Tutor
Correct. The SIP Alg and IPsec Alg functions are enabled by default with no ability to disable for any of the public release firmwares. With these enabled, WiFi calling does not work on the CAX80 for many devices as many users have reported.
Daydemon brought this issue up to the engineers back in 2020 and they created the beta firmware 2.1.3.1 to correct this issue, but never implemented it into the future releases.
Mar 22, 2023Guru - Experienced User
Ok, I'll get this back on NGs plate for review as see if we can make sure this is fully resolved.
I'll be checking my newly installed CAX30 as well for this.
- buckduck12Mar 22, 2023TutorPerfect, thank you!
- FURRYe38Mar 22, 2023Guru - Experienced User
đ
