buckduck12
Mar 17, 2023Tutor
Looking for Netgear CAX80 Beta Firmware 2.1.3.1
Looking for beta firmware version 2.1.3.1 for my netgear CAX80. I read through the forums and found that the only way to fix the WiFi calling issue with this device (ipsec alg) is to install firmware...
TheCountChuckul
Apr 09, 2023Initiate
Hey, I just got support from Netgear, and I was able to fix it with my current firmware (2.1.5.2)
May require a reboot. I did out of habit after I changed my settings.
- buckduck12Apr 09, 2023TutorWiFi calling works on your device with the latest firmware?
- FURRYe38Apr 10, 2023Guru - Experienced User
Got reports back from other users that SIP ALG when enabled with WiFI Calling on CAX30.
I recommend first try with SIP ALG disabled then enabled with WiFI Calling. - TheCountChuckulApr 10, 2023InitiateNot until I changed those settings.
