buckduck12
Mar 17, 2023Tutor
Looking for Netgear CAX80 Beta Firmware 2.1.3.1
Looking for beta firmware version 2.1.3.1 for my netgear CAX80. I read through the forums and found that the only way to fix the WiFi calling issue with this device (ipsec alg) is to install firmware...
buckduck12
Apr 09, 2023Tutor
WiFi calling works on your device with the latest firmware?
Apr 10, 2023Guru - Experienced User
Got reports back from other users that SIP ALG when enabled with WiFI Calling on CAX30.
I recommend first try with SIP ALG disabled then enabled with WiFI Calling.
