buckduck12
Mar 17, 2023Tutor
Looking for Netgear CAX80 Beta Firmware 2.1.3.1
Looking for beta firmware version 2.1.3.1 for my netgear CAX80. I read through the forums and found that the only way to fix the WiFi calling issue with this device (ipsec alg) is to install firmware...
buckduck12
Apr 10, 2023Tutor
There were no SIP alg options for me until I downloaded the 2.1.3.1 firmware.
- FURRYe38Apr 10, 2023Guru - Experienced User
SIP ALG should be seen in the more recent version of release FW. I know mine has it.
Something to try a Factory Reset and setup from scratch next time you update FW.
I guess use what works for you for now. NG is working on the CAX30 currently. We are testing new FW out since it saw a problem back in Jan. I'll be sure to keep the CAX80 on NG radar and hope we'll be coming back to put the CAX80 on the forefront to help get issues fixed. Please be patient.
