Steve_Y
Oct 30, 2023Aspirant
Looking for wired router compatible with CM1000 link aggregation
I have a CM1000 cable modem. It has two gigabit ports that can be used together via link aggregation. I'm looking for a reasonably priced wired router that supports the protocol. The router will b...
Oct 30, 2023Guru - Experienced User
Ubiquity Edge Router X is a wired only router. Any router will work.
