Steve_Y
Oct 30, 2023Aspirant
Looking for wired router compatible with CM1000 link aggregation
I have a CM1000 cable modem. It has two gigabit ports that can be used together via link aggregation. I'm looking for a reasonably priced wired router that supports the protocol. The router will b...
Steve_Y
Oct 31, 2023Aspirant
plemans My original question apparently wasn't worded very well.
The CM1100 offers link aggregation. I'm trying to use this feature to get a faster WAN pipe between the cable modem and a non-wifi router. (That's what I meant by a wired router.) By reasonable, I'm thinking around $100.
FURRYe38 I'm looking through the Ubiquity manual, and I don't see where it supports link aggregation.
ER-X Quick Start Guide
So far, the only routers that I've read about, that support this are Wireless routers. My wireless AP is not close to where I have the cable modem, switches and the rest, so making it the main router would involve a lot of cabling.
Oct 31, 2023Guru - Experienced User
thats a bit of a challenge to get a router that supports dual wan (port aggregation) for under $100.
Its possible but usually you either have to get an older device, a non-wireless one (see edge routerX), or get extremely lucky.
The link I posted prior has "applied to devices". that shows the routers that netgear has the support wan port aggregation
- Steve_YOct 31, 2023Aspirant
plemans I am looking for a non-Wireless router. For the link you posted, all the "applies to devices" are Wireless routers. As far as I can tell, Netgear doesn't have any non-Wireless routers that support link aggregation for the WAN side of things.
I looked at the Ubiquiti EdgeRouter X, and it doesn't appear to support it either.I'll try other resources to get my answer. Thanks for the replies.
- FURRYe38Oct 31, 2023Guru - Experienced User
You might do a bit more digging to check LACP support on Ubiquiti Edge Routers:
https://www.youtube.com/watch?v=GovGfRhlkxQ
I'm sure there are other resources mentioning LACP on there routers.
