Steve_Y
Oct 30, 2023Aspirant
Looking for wired router compatible with CM1000 link aggregation
I have a CM1000 cable modem. It has two gigabit ports that can be used together via link aggregation. I'm looking for a reasonably priced wired router that supports the protocol. The router will b...
Steve_Y
Oct 31, 2023Aspirant
plemans I am looking for a non-Wireless router. For the link you posted, all the "applies to devices" are Wireless routers. As far as I can tell, Netgear doesn't have any non-Wireless routers that support link aggregation for the WAN side of things.
I looked at the Ubiquiti EdgeRouter X, and it doesn't appear to support it either.
I'll try other resources to get my answer. Thanks for the replies.
Oct 31, 2023Guru - Experienced User
You might do a bit more digging to check LACP support on Ubiquiti Edge Routers:
https://www.youtube.com/watch?v=GovGfRhlkxQ
I'm sure there are other resources mentioning LACP on there routers.
