SunnahWay
Apr 12, 2023Aspirant
Losing connection Intermittently CAX80
For the past 3 weeks I have been losing connection multiple times in the day and I cannot figure it out. I my cable ISP (COX) has confirmed the connection from their side is good and I have reset the...
Apr 12, 2023Guru - Experienced User
What Wi-Fi devices do you have connected?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wi-Fi Neighbors near by? If so, how many?
Wi-Fi LEDs will blink for any connection activity.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
SunnahWay
A COX technician is coming today to investigate the outside and inside connection. I will update after I know more. Thanks.
- FURRYe38Apr 12, 2023Guru - Experienced User
