Hardworker
May 03, 2017Aspirant
Loss of home wi-fi newwork
Have CG3000D modem/router for 4 years. WiFi connection was just my default (network) setting which appeared when I connected the unit. Last week, after the Cox cable repairman left I no longer had th...
DarrenM
May 05, 2017Sr. NETGEAR Moderator
Hello Hardworker
To get it back to the default you just need to do a factory reset by holding the reset button for 10 seconds.
DarrenM
Hardworker
May 05, 2017Aspirant
Darren,
Thank you for your suggestion.Tried it twice without results. Is there anything else I can try?
- DarrenMMay 08, 2017Sr. NETGEAR Moderator
Hello Harworker
Do you have a pc connect via ethernet? if so bring up a web browser and go to 192.168.0.1 should prompt you to log in and use admin/password to login after that go to the wireless settings and you should be able to change the name and password of the wireless.
DarrenM
