TOC719
May 07, 2020Guide
Lost Printer in Netgear USB CC after installing new C3000A Modem
Replaced C3000A Modem with new C3000A Modem.
Netgear USB CC nolonger presents Router or Printer. Readyshare worked fine before replacement.
Rebooted.
Uninstalled/Reinstalled.
Any ideas?
Explored Ethernet connection as you suggested. I now have two of three computers printing wirelessly!
I think that I have the network setup as you showed, but I don't see Router mode on C3000A. I have the C3000A set as it came. The Netgear is in AP mode.
I reconnected the printer via ethernet (no USB) and it showed on the corresponding table (C300A and Netgear) or map (Netgear Genie) as a Dell 1320C priinter. Pinged printer from one of the computers. Started trouble shooting IP address, etc and got the printer to print a test page from 2 of 3 computers. New problem on the third.
We're good to go.
Thank you. I appreciate that you kept coming back.
Did you put the C3000A in passthrough modem only mode?
Or the netgear in Access point mode?
otherwise, both are running in router mode and you're in a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
