lstorey
Nov 17, 2015Aspirant
MAC Address Filtering By Schedule on CG3000DV2
I am trying to set up a schedule so that my son's internet is cut off at 10:30pm and then re-established the next day at 9:30am. I have gotten as far as adding the devices to the MAC filter list ...
Babylon5
Nov 18, 2015NETGEAR Employee Retired
As a crude work-around to your scheduling issue, you could change the router timezone to suit. So for example if you wanted a schedule to run from 23:00 to 01:00 you could shift the router timezone by two hours and set the schedule to run from 21:00 to 23:00.
Sorry but I’m not familiar with the CG3000 so don’t have an answer to your last question.
