yasirfaheem
Jan 23, 2024Guide
Maximum download and upload speed of the cm1200 cable modem?
What is the maximum download and upload speed of the cm1200 cable modem? I have Comcast and am paying for 800mbps download and 100mbps upload. When I have the cable modem connected directly to my c...
Jan 23, 2024Guru - Experienced User
I would presume 100Mpbs on the up should be there since WAN ports support 1Gb.
Last time I had mine online I only saw 50mbps however tha'ts all my ISP supports, even currently.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
Have you connected a wired PC directly to the back of the modem with out any wifi router in the middle to check speeds?
Test with a different wired PC to compare results?
What speed test app are you using? Recommend using Ooklas installable speed test app rather than the web based version.
yasirfaheem
Jan 23, 2024Guide
I am using a cat 6a thin cable from the cable modem to the router. Then from the router to the switch cat 6a thin cable. Then from the switch to the computer is a cat 6a thin cable.
My cable modem is connected to an Asus zenwifi ax mini (xd4) mesh wifi system with 3 nodes throughout my house.
When I go from cable modem to my computer using a cat 6a thin cable and run a speed test I get 950mbps down and 23mbps upload. This is the same speed I get when I go through my router and switch.
I have tried to speed test with a 2018 macbook pro and a dell precision 5760 laptop. Both give the same speeds.
The speed test app that I was using was speedtest.net and speedtest.xfinity.com
