yasirfaheem
Jan 23, 2024Guide
Maximum download and upload speed of the cm1200 cable modem?
What is the maximum download and upload speed of the cm1200 cable modem? I have Comcast and am paying for 800mbps download and 100mbps upload. When I have the cable modem connected directly to my c...
yasirfaheem
Jan 23, 2024Guide
When I go from cable modem directly to my computer by passing my router using a cat 6a thin cable and run a speed test I get 950mbps down and 23mbps upload.
Jan 23, 2024Guru - Experienced User
Something to ask the ISP about. There making changes to there service so they are making changes here and will determine what is support UP and Down per model modems.
Some ISPs will automatically put CM1000 - 1200 to higher upload speed tier when their networks can support higher upload speed. If any TV set top boxes are present, would need to be removed or have the ISP set up different ISP service coax line to the modem and the other just for TV services. The up load is all dependent upon ISP services and support. CM can handle it if the service and quality on the line is good. ISP is responsible for that.
Would need to see the two data logs from the modem to see if there maybe issues seen there.
Also swap cabling as a test as well. CAT6 UTP non thin cabling would be recommended.
