Easywriter2222
Jul 25, 2022Follower
MBS Speed on my C6300 Cable Modem Router
The cable company I use is sending a signal of 300 MBS, but my speed test is only showing 57 MBS I called Netgear after the Cable Company said the problem is my router/modem and NetGear wants to c...
Jul 25, 2022Guru - Experienced User
How are you testing speeds?
Wired? wireless?
what wired speed do you get?
What device are you testing on?
What 5ghz speeds do you get?
