mamamia1961
Oct 03, 2022Follower
merge netgear accounts
I need to merge two Netgear accounts and need some help please. each account has a different router registered I now have a 16x4 DS3.0 AC1200 Cable Modem Router (C6230) thanks for all the hel...
Oct 04, 2022Guru - Experienced User
I would reach out to NG support.
Can try removing the product from one account and then see if you can add it to another:
