5MissingOnOne
May 15, 2018Aspirant
Missing 5 GHz
I have 3 devices connected but one of them can't see the 5 GHz setting. - HP ENVY dv7 Notebook PC
DarrenM
May 24, 2018Sr. NETGEAR Moderator
You could try to change the SSID on the 5ghz network just to troubleshoot see if it shows up.
DarrenM
5MissingOnOne
May 25, 2018Aspirant
Are you talking about changing the name? If I do that, will the other devices that use it, get kicked off and then I'll have to log in on all of those again?
I do see it on other devices.
