Kikyo145
Mar 20, 2025Initiate
Missing power cable
Nighthawk AX8 wifi cable modem Router AX6000. MODEL: CAX80.
Brought more than a year ago and does not have power cord. Having issues trying to find a 19V/3.16A cord that works with this modem. If anyone has an suggestions as to where to buy one it would be much appreciated. Have tried local stores and Amazon, they only cords recommended are for laptops with a pin inside. Need a power supply, big enough without a pin.
- JdpaAspirantHave you found a power supply. This same thing happened to me, no power supply shipped.
- Kikyo145Initiate
Was unable to find new cord that works. Just decided to break the pin in middle for the laptop charger to get it to fit in. The modem does not receive the signal properly so we have decided to trash it and just go with company supplied.
The power supply linked to amazon should have worked. Would be the only one that would fit the CAX80. If you didn't try this adapter then you didn't use the right adapter. Your laptop charger may have not been good enough to power the CAX80.
Did you throw away the CAX80?
