Bevie12
Oct 03, 2022Follower
Model C3000
My modem is online and shows connected to the TV but none of the Apps work. I cannot connect my phone either but my laptop is connected and working. Any suggestions as to why my phone or TV are not...
Oct 04, 2022Guru - Experienced User
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
