Ernien54
Jan 31, 2021Aspirant
Model C3700v2 Slow Download/Upload speeds
Xfinity checked their end and now suggested for Netgear to send a "Hit"? to the router. They ran tests on their end and made improvents on their end. No improvment from the router. Router has been ...
Jan 31, 2021Guru - Experienced User
Are those speeds wired?
wireless?
over 2.4ghz or 5ghz?
What device are you using to test speeds with?
And what website?
- Ernien54Feb 01, 2021Aspirant
The speeds are wireless using the Xfinity Speed test on my MacBook
it is over 5G
- plemansFeb 01, 2021Guru - Experienced User
what speeds do you get hardwired?
do you have a screen snip of the cable connections page (shows upstream/downstream power levels of the modem) and the event logs?
that lets us check the signal
