Ernien54
Jan 31, 2021Aspirant
Model C3700v2 Slow Download/Upload speeds
Xfinity checked their end and now suggested for Netgear to send a "Hit"? to the router. They ran tests on their end and made improvents on their end. No improvment from the router. Router has been ...
Ernien54
Feb 01, 2021Aspirant
The speeds are wireless using the Xfinity Speed test on my MacBook
it is over 5G
Feb 01, 2021Guru - Experienced User
what speeds do you get hardwired?
do you have a screen snip of the cable connections page (shows upstream/downstream power levels of the modem) and the event logs?
that lets us check the signal
