trdnface
Sep 14, 2019Aspirant
Model C3700v2
I have a C3700v2. I am having a problem connecting to my network. I have had Xfifnity out three times, my lines are ok, I live in a RV park and am using cable connection. I hooked directly to the ped...
trdnface
Sep 15, 2019Aspirant
Thank you for the info, I had the signal checked at the pedistal and inside the RV, could never make it work. Went to Xfinity and got one of their modems and it worked inside right away. Called Netgear and told them my problem and they said it may be a bad modem. Of course whoever I talked to at Netgear probably had no idea what could have been wrong but just gave me an answer. Thanks for the advice..
Sep 17, 2019Guru - Experienced User
If a different modem works and the NG doesn't, possible the NG modem is faulty.
