noah_swett
Sep 08, 2022Aspirant
Model C6250 2.4 ghz drops internet connection
The arris dg3260 I rent from my provider works great. I bought this unit to try and save a few bucks on my internet bill.
I only have trouble with the 2.4 ghz band, the 5 ghz and Lan work fine.
I run a makeshift smart home. (Amazon Echo, SmartHub, lights , etc) and all of my devices, including my phone, loose the internet connection on the 2.4 ghz band.
I have a few neighbors with WiFi, but I made sure to set the channel to one they aren’t using. (Channel 11)
Please help I’m about ready to go Office Space on this thing.
Did you try other channels? It could be that something is broadcasting on channel 11 periodically thats overwhelming it.
- noah_swettAspirantGood thought, but yes I have. It didn’t change anything.
One additional note, speed tests either via app or web browser start fairly strong but quickly slow to a full stop about halfway through. I’ve tried the tests on multiple devices and even different apps, with no success. Again only on the 2.4 ghz band.- plemansGuru - Experienced User
Have you tried a simple factory reset?
