danielghee
Aug 24, 2019Aspirant
Model C6300 - How to fix very low upload speeds - Assistance needed
Hello, I’m using a Netgear cable modem router combined with Xfinity internet service. My service plan allows up to 1000mbps download and 20mbps upload. My current upload speeds are 4-6mbps. I hav...
danielghee
Aug 26, 2019Aspirant
Furry, are you saying I should make sure I have a direct connection from the modem to the ISP without any splitters, correct?
It's odd that I'm getting 400 mbps download and 5 mbps upload. If the issue that you said was the problem, shouldn't my download speed be much closer to my upload speed? Thank you for your help
Aug 26, 2019Guru - Experienced User
Yes, splitters can induce noise or attenuate the signal on the line going to the modem.
Someting to get in contact with your ISP and have them help you ensure the signal is good up the the modem.
ALso be sure you have a supporting PC or mobile device that supports testing of 1000Mbps. Not all PCs can perform this test. Some older single or dual core CPUs are not fast enough. Mobile devices may not be spec'd or designed for this as well. Most newer generation phones should be. Contact the mfr to see.
