Chellobug
Jun 10, 2022Aspirant
MODEL C6300 PLAYSTATION NOT CONNECTING
Hi, I've been trying to play games for 4 days to no avail. I was able to play for a bit using my wifi Hotspot on my phone so I know it's the router. Am I missing something? I've never had problems gam...
michaelkenward
Jun 11, 2022Guru - Experienced User
Not much to go on there.
Play what games on what device?
How is it connected to the modem/router? Wifi? Wired?
What happens when you try? Any error messages?
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Chellobug
Jun 11, 2022Aspirant
I have a Model C6300 for NETGEAR
Play multi-player online games on my Playstation.
My connection is wireless and signal strength is 100%.
When I test my connection, internet connection succeeds but signing into Playstation network fails. I tried this on another Playstation system and the same thing happens.
I have downloaded the online manual for this model and it says to try using a DMZ server or port triggering, but I don't want to mess with anything without guidance first.
- ChellobugJun 11, 2022AspirantOkay, so my Playstation 4 works. I am trying to login to a beta server on my PS3 to play Socom: Confrontation. I use a primary and secondary DNS in order to log in but I have recently moved and use a different NETGEAR. A friend told me that the device may be blocking that DNS so I entered it in the NETGEAR wireless setting. Tried resetting router and it still won't let me use the server.
- FURRYe38Jun 11, 2022Guru - Experienced User
What happens if you put the PS console temporarily in the the modems DMZ?
Remote the DMZ setting after testing this.
- michaelkenwardJun 11, 2022Guru - Experienced User
You may have to explain what that means and how to go about it.
It means nothing to me.
