Chellobug
Jun 10, 2022Aspirant
MODEL C6300 PLAYSTATION NOT CONNECTING
Hi, I've been trying to play games for 4 days to no avail. I was able to play for a bit using my wifi Hotspot on my phone so I know it's the router. Am I missing something? I've never had problems gam...
Chellobug
Jun 11, 2022Aspirant
I have a Model C6300 for NETGEAR
Play what games on what device?
Play multi-player online games on my Playstation.
How is it connected to the modem/router? Wifi? Wired?
My connection is wireless and signal strength is 100%.
What happens when you try? Any error messages?
When I test my connection, internet connection succeeds but signing into Playstation network fails. I tried this on another Playstation system and the same thing happens.
I have downloaded the online manual for this model and it says to try using a DMZ server or port triggering, but I don't want to mess with anything without guidance first.
Chellobug
Okay, so my Playstation 4 works. I am trying to login to a beta server on my PS3 to play Socom: Confrontation. I use a primary and secondary DNS in order to log in but I have recently moved and use a different NETGEAR. A friend told me that the device may be blocking that DNS so I entered it in the NETGEAR wireless setting. Tried resetting router and it still won't let me use the server.
- FURRYe38Jun 11, 2022Guru - Experienced User
What happens if you put the PS console temporarily in the the modems DMZ?
Remote the DMZ setting after testing this.
- michaelkenwardJun 11, 2022Guru - Experienced User
You may have to explain what that means and how to go about it.
It means nothing to me.
