BruceE
Feb 22, 2021Follower
Model #C7000
I am setting up a Google Mesh Sysytem. How do I turn off the Wifi part of the modem/router ? Any information would be helpful. Thank you, BruceE
Feb 22, 2021Guru - Experienced User
there's a guide to putting it in modem only mode.
How to set the cable modem/router to be on modem only | Answer | NETGEAR Support
michaelkenward
Feb 23, 2021Guru - Experienced User
Or read the manual.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Cable Your Modem Router to a Router and Use Bridge Mode or, depending on what you want to do, Enable or Disable the Wireless Radios.
