agt0630
Aug 04, 2020Follower
model c7000v2 contracted for 200 M 0nly getting 50
Router wont come up to speed....200M. Only getting 50. Wowway couldnt fix it.......said I needed to talk to Netgear. What do I need to do?
Aug 04, 2020Guru - Experienced User
Test speeds with a wired PC?
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
