verna1953
Jul 06, 2023Aspirant
Model C7000v2 help
just purchased this last August and now I can not use it unless its 10G for Xfinity. Actually I can use it but its so very slow now and alot of pages will not load. I do not know what to do. The pric...
Jul 06, 2023Guru - Experienced User
This model modem can't and will never do or see or support 10Gb. Max speed support is 1Gb.
Ask the ISP to set your ISP speed tier to 800Mpbs or 1Gb for the download.
Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
- verna1953Jul 06, 2023Aspirant
I will do all this tomorrow but it is a combo router and modem. Thank you for answering me so quickly. If I should purchase a new router can you tell me what to get, I have quite a bit that is wireless in the home. I have about 20 items in the home that is wireless but not all at one time. Also the home is a tri-level I am sure that matters too.
- FURRYe38Jul 06, 2023Guru - Experienced User
Whats ths size of the home?
Possible you might look in to some MESH, Orbi or MK systems.- verna1953Jul 07, 2023Aspirant
the home is around 2000 sq ft but its a tri-level which means there are 3 floors but they are staggered
- plemansJul 07, 2023Guru - Experienced User
You don't really need to purchase anything.
What actual speed do you pay for?
If its under gigabit, you can still use the C7000 as a standalone modem or use it as a modem/router and add an extender.
got a screensnip of the cable connections page and event logs? Usually when people are having lower speeds, we see line issues.
I am sorry could you tell me where to find the cable connection page please?
Is there a way to remove all my devices from the netgear login and start all over? That way I can name what is on there
