verna1953
Jul 06, 2023Aspirant
Model C7000v2 help
just purchased this last August and now I can not use it unless its 10G for Xfinity. Actually I can use it but its so very slow now and alot of pages will not load. I do not know what to do. The pric...
verna1953
Jul 08, 2023Aspirant
screenshot 2
verna1953
- KitsapJul 08, 2023Master
What device are you using to connect to your modem/router, a computer or mobile device?
If a computer, are you using Windows or Mac?
If a mobile device, are you using Android or Apple?
How are your connecting, via Wi-Fi or over Ethernet?
If Wi-Fi, 2.4 GHz or 5 GHz band?
For testing throughput, recommend you use the Ookla stand alone test application. Available in the play store. With this application, there is no web browser to get in the way.
