B1363
Apr 18, 2020Follower
Model C7800 Computer Unable to connect using VPN
I'm trying to work from home but my computer will not connect through the VPN. I'm using Dell Sonicwall Global VPN Client with Windows 10. The computer will connect through the VPN at other sites, so...
Apr 19, 2020Guru - Experienced User
B1363 wrote:I'm trying to work from home but my computer will not connect through the VPN. I'm using Dell Sonicwall Global VPN Client with Windows 10. The computer will connect through the VPN at other sites, so IT thinks it's our router that is cousing the problem. Our router is the AC3200 model C7800 with Cox cable. I have read many tips related to different routers but this router is different so non of the solutions work.
Your companies IT thinks that?
Did you try contacting the VPN provider "sonicwall"?
Maybe they know what specifics need to be done for their vpn client to run on specific devices.
Hughle
Oct 10, 2020Aspirant
The reason I know the problem at the router because, I connected my laptop via my cell phone hotspot, then I can connect to device at work via the VPN connection.
- plemansOct 11, 2020Guru - Experienced User
Not saying its not the router but your vpn might need specific ports/setup for it to work
- HughleOct 11, 2020Aspirant
You referred incoming VPN traffic, but I am doing outgoing VPN connection.
- HughleOct 12, 2020Aspirant
Urgent, please help! Is there any fix for VPN connection issue? My laptop could not establish VPN connection if it is behind C7800 router. If I switched Wifi connection to cell phone hotspot, then I could establish the VPN connection.
