B1363
Apr 18, 2020Follower
Model C7800 Computer Unable to connect using VPN
I'm trying to work from home but my computer will not connect through the VPN. I'm using Dell Sonicwall Global VPN Client with Windows 10. The computer will connect through the VPN at other sites, so...
Hughle
Oct 10, 2020Aspirant
The reason I know the problem at the router because, I connected my laptop via my cell phone hotspot, then I can connect to device at work via the VPN connection.
Oct 11, 2020Guru - Experienced User
Not saying its not the router but your vpn might need specific ports/setup for it to work
- HughleOct 11, 2020Aspirant
You referred incoming VPN traffic, but I am doing outgoing VPN connection.
- HughleOct 12, 2020Aspirant
Urgent, please help! Is there any fix for VPN connection issue? My laptop could not establish VPN connection if it is behind C7800 router. If I switched Wifi connection to cell phone hotspot, then I could establish the VPN connection.
- FURRYe38Oct 12, 2020Guru - Experienced User
What happens if you put the IP address the Laptop gets from the Modem into the modems DMZ, then try to establish the VPN on the Laptop?
