bubmyster
Oct 03, 2020Aspirant
Model D700 modem router I
Can some tel me if aModel D700 modem router Is it compatible to connect to a Neatgear CMT1000.0 cable modem 3.0
- Oct 04, 2020
These two modem models are not comaptible. They are modems which get the internet services from ISP services. The D series is a DSL modem with a built in router and wifi. The CM is just a Cable modem only. IF your using the CM cable modem now, it's best to install a new external wifi router, something like NGs R or RAX series class router or NGs Orbi wifi mesh system.
Good luck.
bubmyster wrote:Can some tel me if aModel D700 modem router Is it compatible to connect to a Neatgear CMT1000.0 cable modem 3.0
Oct 04, 2020Guru - Experienced User
Good luck.
bubmyster
Oct 04, 2020Aspirant
Thank for all your help will replace router.
- FURRYe38Oct 04, 2020Guru - Experienced User
:smileywink:
- antinodeOct 04, 2020Guru
> These two modem models are not comaptible. [...]
Nonsense. Is that why the D7000 User Manual has a sextion entitled
"Install and activate your Cable Modem"?> [...] The D series is a DSL modem with a built in router and wifi. The
> CM is just a Cable modem only. [...]So, use the CMxxxx cable modem and the wireless-router parts of the
Dxxxx. As explained in the Dxxxx User Manual. It's not complicated.> Good luck.
Indeed. You'll need it if you believe everything you're told here.
