Marleysmom
May 01, 2016Follower
Model R6100 type of encryption does it use?
Setting up new Tivo-- needs to know type of encryption it uses. AC1200
TheEther
May 01, 2016Guru
The R6100 support these wireless security modes:
- None
- WPA-PSK [TKIP]
- WPA2-PSK [AES]
- WPA-PSK [TKIP] + WPA2-PSK [AES]
- WPA/WPA2 Enterprise
You will have to log into your router and go to BASIC > Wireless to see which mode your router is using. WPA2-PSK [AES] is recommended because it is the strongest. Use WPA-PSK [TKIP] + WPA2-PSK [AES] if you have devices that don't support WPA2-PSK [AES].
