PorchSitter
Jun 20, 2016Follower
Model R7800 and a aftermarket directional antenna.
Does the wifi signal exit the C3000 360 degrees around the router? Or, does the signal go farther from the front, rear or sides of the router. (using 2.4 Mhz). I'm trying to position the router so I...
VE6CGX
Jun 21, 2016Master
Then you need some experiment to do. Don't position too close to a wall. From present position start out turning router upto 90 deg. in increment measuring signal level. Then play with antenna stick tilp, bend, etc. Vertical antenna supposes to radiate 360 deg. on theory but in reality the radiation pattern distorts caused by many factors. Also radiation angle. Antenna engineering is very complex empirical stuff. When you talk about gain on an antenna it comes with radiatio. 1 is perfect). If SWR is high it can even damage the radio or cause poor erp wasting RF energy as heat.
Generally good router location in a house is higher, central location.
