Natims
Mar 15, 2025Aspirant
ModelC3700v2 doesn't have a reset hole to put paper clip. How do I do a factory reset?
Netgear Model# C3700v2 does not have a reset button, nor a hole to put paperclip to reset. Just on and off. How do I perform a factory reset?
Kitsap
Mar 15, 2025Master
Natims wrote:Netgear Model# C3700v2 does not have a reset button, nor a hole to put paperclip to reset. Just on and off. How do I perform a factory reset?
It is on the bottom! See the attached screen snip from the user manual.
Recommend you go to the Downloads section above and download the user manual.
