Natims
Mar 15, 2025Aspirant
ModelC3700v2 doesn't have a reset hole to put paper clip. How do I do a factory reset?
Netgear Model# C3700v2 does not have a reset button, nor a hole to put paperclip to reset. Just on and off. How do I perform a factory reset?
Mar 16, 2025Guru - Experienced User
And as an aside, the C3700 is pretty old and a slow device. Might be coming up on time to start saving for a newer generation device
