Balalehabashi
Sep 08, 2023Aspirant
Modem’s lights are all blinking
My internet stoped working suddenly and all lights on the modem started blinking. Tried everything, turning off and on, disconnecting cables and reconnecting and yet nothing works. The lights are stil...
Sep 08, 2023Guru - Experienced User
Usually if all the lights are blinking like that on modems, it indicates a hardware failure.
What I'd try is disconnect the coax from the modem, then push and hold reset for up to 30 seconds while its still powered on. If its still blinking, it tends to indicate failure. Is it still within warranty?
- BalalehabashiSep 08, 2023AspirantThat did not work unfortunately. All lights are still blinking.
- plemansSep 09, 2023Guru - Experienced User
tends to indicate a hardware failure then.
If you're within your warranty, I'd start a support case with netgear
