QuantumMan
Oct 10, 2019Aspirant
Modem automatically resets every couple minutes.
My modem keeps resetting about every two minutes. All the lights remain green then the upstream and downstream lights start flashing simultaneously in a steady pattern. After that my modem just reboot...
- Oct 21, 2019
Just an update if anyone is expereiencing a similar problem. I bought a new modem and called my ISP to de-register the old modem and registered the new one. Internet has been online and working since I replaced the modem. I'm assuming the modem was faulty.
QuantumMan
Only the power light is solid green and downstream light has a steady blinking green light. All other lights are off.
After about a minute most light start blinking which I’m assuming it’s rebooting itself and the process repeats itself.
When I reset the modem with the coax cable plugged the upstream and downstream lights go back to simultaneous blinking them my modem proceeds to reboot again.
I’m guessing this a modem problem. I’ll go get a replacement modem and update if that fixes my problem. Thanks for your help.
Oct 10, 2019Guru - Experienced User
Yes, get the modem replaced.
