boilermaker8162
Jun 03, 2021Tutor
modem CAX80
Hello, I installed a NetGear Nighthawk AX8 AX6000 WiFi Cable Modem/Router DOCSIS 3.1 CAX80,Firmware Version V2.1.1.4, I have Xfinity/Comcast, plan is 1200mbps upload, 35mbps upload. Having trouble ...
Jun 04, 2021Guru - Experienced User
Do you have a screen snip of the cable connections page and the event logs?
That helps check the signal from the ISP.
How are you testing speeds? hardwired in? over wireless?
boilermaker8162
Jun 04, 2021Tutor
Tested speeds from wireless as well as wired, tested from 7 different machines. All have about the same upload 5.9gbps max. The original modem from comcast was running at over 40gbps just prior to replacing, my plan calls for 1200 download and 35 upload. Thanks
