boilermaker8162
Jun 04, 2021Tutor
modem CAX80
Hello, I installed a NetGear Nighthawk AX8 AX6000 WiFi Cable Modem/Router DOCSIS 3.1 CAX80,Firmware Version V2.1.1.4, I have Xfinity/Comcast, plan is 1200mbps upload, 35mbps upload. Having trouble ...
Jun 04, 2021Guru - Experienced User
makes it hard to read when you post it like that. Next time get a screen snip. easier to read.
Do you also have you logs?
Any amplifiers/splitters/signal attenuators in your line?
boilermaker8162
Jun 04, 2021Tutor
I'll check the line again, bust last time it was serviced we had everything removed from the line because we no longer have cable, just internet.
