the87hyper
Sep 06, 2024Aspirant
Modem....CM10000v2
So is my modem done, or just need reprogrammed? Its dropping internet..... Time Priority Description 2024-09-06, 19:25:34 Warning (5) DBC-REQ Mismatch Between Calculated Value for P1.6...
Sep 07, 2024Guru - Experienced User
got a screensnip of the cable connections page with the logs?
the87hyper
Sep 07, 2024Aspirant
<tabindex=-1>Startup Procedure</tabindex=-1>
| Procedure | Status | Comment |
| Acquire Downstream Channel | 645000000 Hz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Security | Enable | BPI+ |
| IP Provisioning Mode | Honor MDD | IPv4 only |
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR / MER | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | QAM256 | 12 | 645000000 Hz | 9.0 dBmV | 40.9 dB | 1471353494 | 0 | 0 |
| 2 | Locked | QAM256 | 3 | 591000000 Hz | 7.6 dBmV | 40.1 dB | 1470640845 | 0 | 0 |
| 3 | Locked | QAM256 | 4 | 597000000 Hz | 7.7 dBmV | 40.2 dB | 1470644264 | 0 | 0 |
| 4 | Locked | QAM256 | 5 | 603000000 Hz | 8.1 dBmV | 40.3 dB | 1470648586 | 0 | 0 |
| 5 | Locked | QAM256 | 6 | 609000000 Hz | 8.1 dBmV | 40.3 dB | 1470652597 | 0 | 0 |
| 6 | Locked | QAM256 | 7 | 615000000 Hz | 8.5 dBmV | 40.6 dB | 1470656237 | 0 | 0 |
| 7 | Locked | QAM256 | 8 | 621000000 Hz | 8.5 dBmV | 40.6 dB | 1470660257 | 0 | 0 |
| 8 | Locked | QAM256 | 9 | 627000000 Hz | 8.5 dBmV | 40.7 dB | 1470664169 | 0 | 0 |
| 9 | Locked | QAM256 | 10 | 633000000 Hz | 8.6 dBmV | 40.5 dB | 1470667908 | 0 | 0 |
| 10 | Locked | QAM256 | 11 | 639000000 Hz | 8.8 dBmV | 40.9 dB | 1470671105 | 0 | 0 |
| 11 | Locked | QAM256 | 13 | 651000000 Hz | 9.1 dBmV | 41.0 dB | 1470674878 | 0 | 0 |
| 12 | Locked | QAM256 | 14 | 657000000 Hz | 9.0 dBmV | 41.2 dB | 1470679062 | 0 | 0 |
| 13 | Locked | QAM256 | 15 | 663000000 Hz | 9.2 dBmV | 41.2 dB | 1470682099 | 0 | 0 |
| 14 | Locked | QAM256 | 16 | 669000000 Hz | 8.8 dBmV | 41.1 dB | 1470685628 | 0 | 0 |
| 15 | Locked | QAM256 | 17 | 675000000 Hz | 9.3 dBmV | 40.8 dB | 1470683875 | 0 | 0 |
| 16 | Locked | QAM256 | 18 | 681000000 Hz | 9.3 dBmV | 41.3 dB | 1470687664 | 0 | 0 |
| 17 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
| 18 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
| 19 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
| 20 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
| 21 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
| 22 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
| 23 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
| 24 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
| 25 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
| 26 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
| 27 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
| 28 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
| 29 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
| 30 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
| 31 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
| 32 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
| 1 | Locked | ATDMA | 1 | 17300000 Hz | 37.8 dBmV |
| 2 | Locked | ATDMA | 2 | 23700000 Hz | 37.8 dBmV |
<tabindex=-1>Downstream OFDM Channels</tabindex=-1>
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | 0, 1, 2, 3 | 159 | 276000000 Hz | 3.7 dBmV | 35.8 dB | 886 ~ 3209 | 7043718667 | 1276189869 | 0 |
| 2 | Locked | 0, 1, 2, 3 | 160 | 810000000 Hz | 9.3 dBmV | 33.8 dB | 166 ~ 3929 | 11434663251 | 1783583421 | 0 |
<tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
| 1 | Locked | 3, 4, 9, 10, 11, 12, 13 | 3 | 23700000 Hz | 33.3 dBmV |
| 2 | Not Locked | 3, 4, 9, 10, 11, 12, 13 | 0 | 0 Hz | 0.0 dBmV |
