McGyverdave43's avatar
Nov 20, 2021
Modem CM1000v2 and nether router R6020. Will a switch between modem and computer work?
My netgear router AC750 model R6020 limits my 1GBps internet speed. will a switch between the modem and computer work? The modem has only one port.
  • FURRYe38's avatar
    You may need a newer R series router to support 1Gb ISP speeds. Also ensure your ethernet adapters are supporting of 1000mpbs connection rates.
  • plemans's avatar
    What modem is it?
    If its a modem only device, you can't put a switch between the modem and the router.
