Vferia
Jul 31, 2020Follower
MODEM CM1100 CONNECTED TO R6900 WIFI/ROUTER
I just replaced the Motorola Cable Modem with Netgear CM1100. Activated it (xfinity) and got internet connection. I reconnected the R6900 wifi/router. The problem is only one port has the internet a...
Aug 02, 2020Guru - Experienced User
Factory reset the router and setup from scratch. Review the user manual and installation guide for your model router.
Please post about any R router series questions in the following forum for your model router:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Good Luck.
Vferia wrote:I just replaced the Motorola Cable Modem with Netgear CM1100. Activated it (xfinity) and got internet connection. I reconnected the R6900 wifi/router. The problem is only one port has the internet access. Wifi and the other ports are not connected to the internet.
What to do?
