kkester
Nov 03, 2021Tutor
Modem CM700 Ethernet light is blinking orange/flickering orange.
Is this an issue? All of the lights are solid green besides that one and I have internet connection. Just want to know if this is an issue or will I continue to get steady connection?
Nov 03, 2021Guru - Experienced User
What is the brand and model of the host wifi router connected to the modem?
The ethernet LED should indicate "Green" for 1000Mpbs and If it's "Amber" then it maybe indicating a 100Mpbs connection with your external wifi router or the computer you have connected to it.
Review the user manual to see what the LED behaviors are for the modem.
kkester
Nov 03, 2021Tutor
Linksys AC1200
- FURRYe38Nov 03, 2021Guru - Experienced UserReview the specs sheet for that model router if this is the one you have: https://downloads.linksys.com/support/assets/datasheet/e5400-router-ac1200-datasheet-upd-eng.pdf - kkesterNov 03, 2021TutorAre you implying that I need to get a better router? I’m sorry, I’m new to all of this.- FURRYe38Nov 03, 2021Guru - Experienced UserThe spec sheets says that the WAN/LAN ports on this particular model only support 10/100Mpbs while the CM700 supports up to 1000Mpbs. The CM works with 100Mpbs however any speed testing you do over wired or wireless will max out at around 100Mpbs. If you get a ISP speed package thats over 100Mpbs, you'll never see higher speeds with this router.
