kkester
Nov 03, 2021Tutor
Modem CM700 Ethernet light is blinking orange/flickering orange.
Is this an issue? All of the lights are solid green besides that one and I have internet connection. Just want to know if this is an issue or will I continue to get steady connection?
kkester
Jan 28, 2022Tutor
I have a lynksys router model number E5350, it says it is AC1000, light on my modem still blinking orange, what router should I get?
Jan 28, 2022Guru - Experienced User
the Linksys E5350 doesn't have gigabit ports. Only 10/100mbps ports.
You'd need to upgrade to a gigabit router for faster speeds.
- kkesterJan 28, 2022TutorOkay. I am at bestbuy right now, is there any you would recommend? I have 1G wifi w Suddenlink
- plemansJan 28, 2022Guru - Experienced User
Sorry, got this a bit late. What did you go with?
- kkesterJan 28, 2022TutorLinksys Dual Band Wifi 6 Router AX5400, made sure it had 1 gigabit capability and is working great. Orange light that was previously on on my modem is now green.
- plemansJan 29, 2022Guru - Experienced User
Glad it took care of the issue! if you mark it solved, it'll help others with the issue (and keeps others from trying to fix it further)
