kkester
Nov 03, 2021Tutor
Modem CM700 Ethernet light is blinking orange/flickering orange.
Is this an issue? All of the lights are solid green besides that one and I have internet connection. Just want to know if this is an issue or will I continue to get steady connection?
Jan 28, 2022Guru - Experienced User
Sorry, got this a bit late. What did you go with?
kkester
Jan 28, 2022Tutor
Linksys Dual Band Wifi 6 Router AX5400, made sure it had 1 gigabit capability and is working great. Orange light that was previously on on my modem is now green.
- plemansJan 29, 2022Guru - Experienced User
Glad it took care of the issue! if you mark it solved, it'll help others with the issue (and keeps others from trying to fix it further)
