Badcorgi's avatar
Sep 22, 2020
Modem Connection Drop
Just upgraded to Xfinity Gig internet speed. Bought a CM1150V modem to accomodate 1gbps speed and replaced my Arris Surfboard. Install of CM1150V was long and difficult but Xfinity finally recognized it. 950 mbps speed was immediate and steady for about a week. Suddenly, internet speed dropped intermittently to ~1-2mbps while streaming Xfinity TV on my tablet at 3 a.m.  Then speed would suddenly blast back up to 950 mbps. Thought the problem was my 4 year old Nighthawk Router (R7000) so I bought a new Nighthawk (RAX50). Still have the problem. Mostly happens in the very early to mid morning hours for some strange reason. Xfinity says my connection is clear but plans to install a new underground cable line. Netgear tells me the problem is likely the number of locked and not locked channels in the upstream and downstream bonded channels. Xfinity has queried my modem and says it identified a timeout value for the boot file.  This is driving me crazy and will just ask Netgear to send me a replacement modem once the cable line is laid.  Anybody have similar experiences?  Thanks
  • plemans's avatar
    do you have a screen snip of the cable connections page and logs? That actually helps check the line.
      • plemans's avatar
        do you also have the cable connections page?
