lacamastraveler
Apr 12, 2024Aspirant
Modem Dropout
My CM 1000 lately has lost communication. Sometimes it quickly comes back on, other times I have to reboot and twice I've had to call TDS and have them send me a boost. It went off around 10 a...
- Apr 13, 2024
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem. Thats on them.
Apr 12, 2024Guru - Experienced User
Please post a copy and paste of the modems connection status page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
lacamastraveler
The Cable Connection Status is Good
My Router is Synology RT2600ac with a mesh Synology MR2200ac in another location.
The cable is labeled Cat 5e
Are you saying you think the problem is not the modem, but the communication with the router?
Thank you.
- FURRYe38Apr 12, 2024Guru - Experienced User
WE need to see that data from the cable connections page. There is a long page there of data that you can copy and paste here in the forums so we can see the values there. Help to determine more if this is a signal issue rather then a modem issue. Many factors on the ISP signal can be a cause of modems not working right. The events log points to that already.
- lacamastravelerApr 12, 2024Aspirant
Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency <tabindex=-1>Startup Procedure</tabindex=-1>
Procedure Status Comment Acquire Downstream Channel 597000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enable BPI+ IP Provisioning Mode Honor MDD IPv4 only <tabindex=-1>Downstream Bonded Channels</tabindex=-1>
Channel Lock Status Modulation Channel ID Frequency Power SNR / MER Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked QAM256 31 597000000 Hz -0.5 dBmV 41.4 dB 24695975 0 0 2 Locked QAM256 1 417000000 Hz -1.9 dBmV 41.8 dB 23427166 0 0 3 Locked QAM256 2 423000000 Hz -1.9 dBmV 42.0 dB 23436403 0 0 4 Locked QAM256 3 429000000 Hz -1.4 dBmV 41.9 dB 23445679 0 0 5 Locked QAM256 4 435000000 Hz -1.3 dBmV 41.8 dB 23454657 0 0 6 Locked QAM256 5 441000000 Hz -1.6 dBmV 41.6 dB 23464314 0 0 7 Locked QAM256 6 447000000 Hz -2.1 dBmV 41.6 dB 23473373 0 0 8 Locked QAM256 7 453000000 Hz -2.2 dBmV 41.7 dB 23482447 0 0 9 Locked QAM256 8 459000000 Hz -1.5 dBmV 42.1 dB 23492093 0 0 10 Locked QAM256 9 465000000 Hz -0.5 dBmV 42.2 dB 23501586 0 0 11 Locked QAM256 10 471000000 Hz -0.7 dBmV 42.0 dB 23511114 0 0 12 Locked QAM256 11 477000000 Hz -1.6 dBmV 41.4 dB 23520328 0 0 13 Locked QAM256 12 483000000 Hz -2.1 dBmV 41.4 dB 23529785 0 0 14 Locked QAM256 13 489000000 Hz -1.6 dBmV 41.6 dB 23538994 0 0 15 Locked QAM256 14 495000000 Hz -0.3 dBmV 42.2 dB 23548046 0 0 16 Locked QAM256 15 501000000 Hz 0.5 dBmV 42.7 dB 23557764 0 0 17 Locked QAM256 16 507000000 Hz -0.1 dBmV 42.3 dB 23567435 0 0 18 Locked QAM256 17 513000000 Hz -1.6 dBmV 40.8 dB 23576606 0 0 19 Locked QAM256 18 519000000 Hz -2.1 dBmV 40.7 dB 23585753 0 0 20 Locked QAM256 19 525000000 Hz -1.3 dBmV 41.4 dB 23595021 0 0 21 Locked QAM256 20 531000000 Hz 0.0 dBmV 41.9 dB 23604317 0 0 22 Locked QAM256 21 537000000 Hz 0.8 dBmV 42.6 dB 23613485 0 0 23 Locked QAM256 22 543000000 Hz 0.1 dBmV 42.5 dB 23622808 0 0 24 Locked QAM256 23 549000000 Hz -0.8 dBmV 41.9 dB 23632267 0 0 25 Locked QAM256 24 555000000 Hz -1.3 dBmV 41.4 dB 23641413 0 0 26 Locked QAM256 25 561000000 Hz -0.8 dBmV 41.3 dB 23650555 0 0 27 Locked QAM256 26 567000000 Hz -0.4 dBmV 41.5 dB 23660010 0 0 28 Locked QAM256 27 573000000 Hz -0.4 dBmV 41.9 dB 23669382 0 0 29 Locked QAM256 28 579000000 Hz -0.7 dBmV 42.0 dB 23678822 0 0 30 Locked QAM256 29 585000000 Hz -0.8 dBmV 41.7 dB 23686111 0 0 31 Locked QAM256 30 591000000 Hz -0.5 dBmV 41.7 dB 23692354 0 0 32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 <tabindex=-1>Upstream Bonded Channels</tabindex=-1>
Channel Lock Status Modulation Channel ID Frequency Power 1 Locked ATDMA 1 12400000 Hz 50.8 dBmV 2 Locked ATDMA 2 17200000 Hz 51.3 dBmV 3 Locked ATDMA 3 23600000 Hz 52.3 dBmV 4 Not Locked Unknown 0 0 Hz 0.0 dBmV 5 Not Locked Unknown 0 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Hz 0.0 dBmV <tabindex=-1>Downstream OFDM Channels</tabindex=-1>
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power SNR / MER Active Subcarrier Number Range Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked 0, 1, 2 33 741000000 Hz -0.7 dBmV 39.0 dB 148 ~ 3947 6893866 2021045 0 2 Not Locked 0 0 0 Hz -7.2 dBmV 0.0 dB 0 ~ 4095 0 0 0 <tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Locked 3, 4, 5, 6, 9, 10, 11, 12, 13 4 23525000 Hz 52.0 dBmV 2 Not Locked 3, 4, 5, 6, 9, 10, 11, 12, 13 0 0 Hz 0.0 dBmV Current System Time: Fri Apr 12 16:02:26 2024
Ok, signals and power levels on the line look good. Correctables and Un-correctables are zeros which is good.
The ISP needs to take a look at the events log and resolve those items mentioned.
